Sounds like trying to fill but then stops. Program light, end of cycle lights flash once repeatedly. Manual points to continuous flashing being a problem with the inlet / or inlet filter. I have checked water coming out ok from tap but have not tried to clean the inlet valve filter as not sure how.
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
SOURCE: water fills washer, program stops, inlet/drain
Could it be.Try to open and look the fuse inside.Opps try to see the warranty of applian.
SOURCE: flashing then solid water intake
I think your assumptions are pretty close. The filtersensor may be faulty too. If you feel up to it you can do it yourself, but it would be faster to have a appliance guy to do it.,
