FreeMotion 310R Recumbent Exercise Bike Logo
Posted on Mar 24, 2013
I need the manuel for my recumnent bike, freemotion 335R
Bought it at Costco
I am trying to get side cover off of my freemotion 330 r bike i have removed the pedal and all of the screws i am doing this so i can adjust the tension
To remove the side cover of your Freemotion 330 R bike, follow these steps:
  1. Turn off the bike and unplug it from the power source.
  2. Remove the pedal on the side you want to remove the cover from.
  3. Locate and remove all screws that are holding the side cover in place. There may be screws under a cap or sticker.
  4. Carefully pry off the side cover from the bike frame. It may be held in place by clips or other fasteners, so use caution and gentle force to remove it.
  5. Once the side cover is removed, you should be able to access the tension adjustment mechanism.
Note: Make sure you keep all screws and parts in a safe place, and follow the manufacturer's instructions for adjusting the tension.
I have a 350R freemotion that became unplugged. Believe it or not I have spent two days trying to find where to plug it in. Please help
The bottom front portion of the bike should be where the power insert is located. If you have further issues, please reference the bike manual diagram or you can call the manufacturer at 1 800-201-2109.
Thank you.
Cannot change resistance on my freemotion 335R bycicle
If it is battery operated (batteries are in the console) change them first.
If that isn't the problem, you need to open up the bike and check the servo motor operation and the eddy mechanism.
Many of the Icon bikes have lifetime warranty on the eddy mech. Check your manual for warranty coverage.
Freemotion 350r recumbelent bike will not change from step workout.
If you wish to get some details; check the site linked here. Pull up older posts.......
http://electro-medical.blogspot.com/
Freemotion 335r
Whats wrong with it?
I have lost my power supply cord to my Freemotion 330R exercise bike. How can I get a replacement?
http://www.buyfitnessonline.com/cat alog/product
Pls order the cable from this site.
Need manual
http://content.costco.com/images/Content/Misc/PDF/666802_UserManual.pdf
Top FreeMotion Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
