SOURCE: my vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
SOURCE: I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
SOURCE: Can't hear sound on Windows Mediaplayer from DVD I recorded
I've been pondering this one for a day or so - at least two possibilities:
1) There is a mute/audio-off hotbutton inside Windows Media Player itself - click on it and see if the audio works. Alternatively, you can try playing a music file in Windows Media Player to see if THAT file has sound.
2) You need a better Codec - the free version of the K-Lite Codec has limited audio support. There are no easy answers to this problem. I frequently use my computer for converting VHS's to DVD, so I finally plunked down the $50 to purchase Nero 9 and all of its codecs. Before that, however, I used VLC Media Player (free) - it has DVD/VOB audio support.
As a side note, if you wanted to use your computer to convert the VHS's to DVD, you would need a plain-old VCR, a red/white/yellow cable, a DVD burner, and a product called the Dazzle DVD Recorder from Pinnacle. You can hook the VCR straight to your computer and burn away. To get the best experience however, I would also get a program like Nero, Roxio, etc. to do the actual DVD burning (although the Dazzle's native software is perfectly capable of doing the job).
-Tha Mp3 Doctor
SOURCE: Magnavox DVD VCR recorder ZV427MG9 A:I can get the
I can't get the player to switch to dvd so I can eject the dvd disc
SOURCE: I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
