I have a whirlpool AWM 1204/4 and the fabric softener is not dispensing into the drum from the drawer. We have been using Calgon tablets in every wash so do not believe it to be a lime scale problem.
Fabric softner trays often clog up, because a little soap powder in the tray by accident tends to block it. If you pull the soap tray out as far as it will go, you will see that there is a bit of the tray right at the back, probably on the left with an arrow or thumb print or indentation in it. If you press down on this it is a catch and it will allow you to remove the tray from the machine completely. Once out of the machine, the fabric softner cover will also lift out. Clean everything throroughly (Tak it outside and turn your garden hose full pressure on all the holes on the tray and then scrub it out with a toothbrush. Put the fabric softner tray mabc in and slide the soap tray back in the machine. This should have fixed it.
