Not sure if you can see this, but I have a KDL46XBR5 and this is the self diagnostic function listed in the service manual.
Six red blinking lights, pause, six more lights may indicate a faulty backlight or a problem related to your backlight. This doesn't necessarily mean you have to replace anything, could be a ground screw is loose, or one of the many cable connectors need to be reseated while the unit is off. See attached to see if this helps.
If not, google "self diagnostic function kdl-37m4000" and see if that helps. At least this should point you in the right direction
SOURCE: KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
SOURCE: picture will not come on
Most likely the thermal fuse has gone bad. Sony part # 191002393 Prett cheap part and east you replace.
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
SOURCE: TV does not turn ON
Sounds like a power supply issue. order a new power supply or trouble-shoot the current. Look for any capacitors that are bulged up on the top and not flat.
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
Hi, The
Standby/Power light of the TV blinks when there is any internal malfunction in
the TV. The self-diagnostic function of the TV will cause the STANDBY light to
blink or flash when the television detects an issue. The number of times the
STANDBY light flashes corresponds to a specific issue. Few
examples are given below; some of the issues may be resolved without the need
for service. If
the television is plugged into a power strip or surge protector, remove it from
the power strip or surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge
protector and not the television. If
the issue continues to occur, service may be required. Thanks
for using Fixya.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a
power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your
set. The set will need to be serviced to allow a technician to determine the
specific issue that needs to be repaired. If the power light flashes three
times in sequence in a Lamp TV, the lamp cover is not securely attached.
Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power
problem.
6 blinks: - This indicates that there is some kind of audio problem with your
set.
7 blinks: - This indicates that there is a temperature problem with your set.
Please check to make sure that the air vents on the sides and back of the set
are not blocked or clogged and there is adequate ventilation around the
television. We recommend that you check and clean the vents periodically to
make sure the set receives adequate air flow. If the problem continues, the set
will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your
set. If the flash sequence is not listed above or the light continues to flash,
follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
