I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Same problem for three of these Vizeo models; but, not for Emerson TV. All are connected separately to cable via analog to digital converters.
I hooked up a GE amplified indoor antenna to my JVC LT-47X579 TV. When I go to Setting and then TV, the tuner option to change it to air from cable is grayed out. What do I need to do to get this changed? In other answers you talk about a digital converter box. Do I need one of those?
