The dryer buzzer for my Frigidaire top load stacked washer/dryer is obnoxiously loud. I have not been able to find a way to either turn down the volume of the buzzer, or to turn it off altogether. Is this possible? If so, how do you do it?
Buzzer mounted to back of control panel.
**UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
Re-assemble the control panel.
As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
Hello Heather Holley - The signal will sound when the cycle ends and briefly every five minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Is this somethig you can advise on how to do? Not sure where the control panel is...
I checked in the back. It is not labeled at all. A series of colored cords are locked together and plugged into a main receptor area. Do you know what color cord operates the buzzer? It doesn't seem like I could just unplug it - is it safe to snip it?
