I have a Loewe Profil Plus, Profil3572Z - 2005 mode. It just won't turn on. There are no red or green lights on. It worked fine the night before and there was no sudden failures. it just stopped working the next day.
Is it a power failure or is there a fuse that I can replace
Loewe Profil 3272: When power button is pushed in, red led comes on followed by green led then both goes off. Dark screen.
1. Found R691 (100 ohms) open circuit. This is on the input side of the standby regulator I691. Replace 100 ohm resistor.
2. Now red led lights up but when switched on by remote control the green led comes on for second and then whole TV shuts down in protect mode. Found diode D557 shorted. Replaced diode and also C558 (2200mfd 50V) for good measure.
Yes but you have to open the tv
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
We also have a profil plus.One night working perfectly the next morning nothing.No sound, no picture no red or green light
Loewe Xelos 5381 ZW. Push on/off button on remote. Green light comes on with red light. Sound for one second. Turns off. No picture appears.
