Its's stuck on this screen when i click ok it keeps popping back up and it won't let me shut it down either
SOURCE: Every time I try to charge the nabi xd the screen still stays black and it won't power up??
First check the charger is working. If you are using a usb cable use a short fat one (less resistance, so more power/amps).
Some times this is a batrery lockout. If you can figure out how to open the unit and unplug/replug the battery that could fix it.... Look to youtube for opening and pulling batrery.
How do I switch from Kidz Mode to Mommy Mode, and vice versa?
To switch to Mommy Mode, simply tap the Menu Key, select Mommy Mode, and enter the password to exit Kidz Mode. To switch back to Kidz Mode, simply tap the Applications View, and then tap the Kidz Mode Icon.
also for customer support phone number is: 1-855-ASK-NABI
