I get static when i plug my hd25's into my computer whether audio is playing or not. Ipod to headphones and it doesnt hapen Computer speakers to computer and it doesnt happen. Its the same story for all jacks. Help please!
I have tons of static on my headphones - put on the stand to recharge and the green light is not coming on - please advise what I should do to make the sound come back and the static go away - thanks
You might check to make sure that your gain isnt to high many times this can negatively effect your sound quality
Testimonial: "Thanks for your response and so how do i go about "changing the gain"?"
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
SOURCE: No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
SOURCE: RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
Hope this helps.
SOURCE: Headphones w/ built-in microphone. Can both work with one jack?
the simple answer is No. The long answer is your laptop/computers headphone output and mic input are completely separate on the sound card. Meaning there are no tie to the audio in on the heaphone lines, and vise versa on the mic/line in. Sorry to disappoint.
SOURCE: My Sennheiser RS 110 headphones won't work. I
First thing is you need to have a signal going to the headphones for them to work. If you are getting a signal the green light should be lit. If only the red lamp is lit the headphones are not getting a signal. If hooked into a television you should have them plugged into a Fixed Output not variable output.. If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones. If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified. Lastly try using an rca to headphone adapter and plug them into a headphone jack. Don
right click on volume click playback devices right click on the headphones icon(or speaker if it is plugged in there) and click properties now scroll over to the levels and adjust volume there also if those headphones have a seperate volume control try adjusting that sometimes if you have multiple volume controls turned up to high you will get that static sound try 85% on all settings then adjust them up and down from the system sound. also make sure that they are all the way plugged in as this can cause the same issue. otherwise they are probably faulty if new or blown. hope this helps
