Toshiba satellite c660 Logo
Jo Boxall Posted on Jan 03, 2018
Toshiba c660 keyboard not working on left side
My Toshiba C660-155 Laptop keyboard has stopped working on the left hand side. All keys in one section have stopped entirely. I have done the BIOS update as well as taking out battery etc. It has not been working for about 8 months so laptop has not been used unless plugged with USB keyboard. Please help!
Man Ana
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 55 Answers
  • Posted on Jan 03, 2018
Man Ana
Contributor
Level 1:
Cheetah:
Answers
55
Questions
0
Helped
16631
Points
83
Just go to toshiba centre
5 Related Answers
LRL Computer
Fred Steinberg
  • 65 Answers
  • Posted on Sep 21, 2007
SOURCE: Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Anonymous
  • 152 Answers
  • Posted on Dec 13, 2007
SOURCE: @ key not working in toshiba laptop
has it ever worked?
it could be that your are pressing the wrong combination buttons or that if its a laptop with a spanish keyboard, the keyboard settings is kind of wrong..
to check if its the keyboard settings, go to control panel and look for something that has to do with lenguaje.. there you can set up the lenguaje you want..
hope that helped..
Anonymous
  • 306 Answers
  • Posted on Jan 18, 2008
SOURCE: Toshiba Laptop Keys Not Working Right
complete system clean and optimization...possibly formate drive and reinstall windows...being that its an old pc, it probably is slow do to needing a good cleaning. if both those resolutions dont work then its the pc.
Anonymous
  • 41 Answers
  • Posted on Jan 19, 2009
SOURCE: my toshiba m200-c2100d shows TBX
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Anonymous
  • 7 Answers
  • Posted on May 06, 2009
SOURCE: BIOS Battery Location of Toshiba Sattelite A15-S127
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws (less than a ton).
5. Re-seat the hard drive, by sliding it in first with the metal tab under the plastic housing, to the left, then puling it to the right. Replace the panel with the one, shorter, F-4 screw. Reseat the battery.
6. Return your model car with reciept. If a reciept cannot be found, use it for store credit.
If you wish to test the battery, simply unplug it and remove the battery for 30 minutes. Then power it on with only the A/C adapter. If no CMOS screen appears, you are good to go.
http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
tip
How to turn on Wireless Switch on your Laptop or Notebook PC
How to turn on the wireless switch on the laptop or notebook
If you have issues in finding the wireless switch on the laptop to turn the wireless on you can refer the below list
1. Dell D600 & D610-Key Board-Fn+F2
2. HP NC4000 & NC4010-Button-Above Keyboard
3. HP NC4220-Button Left Side of Laptop Near USB Port
4. HP NC6000 & NC6220-Button above Keyboard
5. HP NX9010-Button in front side of laptop
6. HP Omni book 6200 Button on Left side of laptop
7. IBM T43 & X32 Keyboard combination Fn + F5 then Click "Turn On"
8. Toshiba M1 & M2 Switch Left side of laptop towards
front
9. Toshiba R100 Switch on the Right side of laptop
10. Toshiba TE2000 Switch on the left side of laptop by Volume ctrl
11. Toshiba Tecra 2100 Switch Left side of laptop by Volume ctrl
12. Sony Vaio - switch on front left
13. Dell - FN,F2 or FN,F8 or FN,F12
14. Acer - FN,F5
15. IBM / LENOVO
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the FN+F5 key-combo.
IBM ThinkPad (General) - Most have software switch or button on Left hand side.
Lenovo T-61 - Slide button on the front of the laptop
16. MEDION
General - Fn+F1 or Fn+F2
17. MSI
General - Antenna-like button close to the power switch
U100 - Fn+F11
18. PACKARD BELL
Easy note B3600 use the Fn+F1
Easy Note E2/MV46/008 - Fn+F1
Easy note W7730, Antenna-like wireless button on the side of the laptop.
MZ36-U024 - Fn+F2
19. PHILIPS
General - Fn+F2 key combo
X54 - Antenna-like button close to the power switch.
20. SAMSUNG
General - Blue button found in the middle section of the keyboard
on Dec 03, 2009 • Computers & Internet
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
My laptop toshiba satellite c660 does not show any wireless connections
Look for a key on the keyboard which has a wireless picture on it,then press that key and the Fn (function) key at the same time when you're on the desktop
2answers
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
2helpful
My toshiba c660-12ta laptop fn key not working on windows 7
Check with the onscreen keyboard..if its working there then...the you have to contact the manufacturer in order to replace the key....if your laptop is out of warranty and you dont need to spend the money...buy a usb keyboard from the market..it will cheap and do all the things for you
My Toshiba Satellite Pro A300-GR laptop wont type the letters o l k i and numbers eight and nine as well as comma - stop - down arrow not working - right arrow not working and delete key not working - also...
You have Number Lock set on your PC - Have a look for a key top right hand side, it will have something like NumLck written on the KEY - you may need to use that Key in combination with the FN key - bottom left of keyboard - there should be a light somewhere on the keyboard which goes on/off as you toggle the NumLck key. You should see different coloured numbers on the key s*()UIOPJKLM These are the numbers and symbols that will be displayed when the NumLock is used
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
