SOURCE: fisher paykel DegX1 replacement cord istallation
Well, of all the problems, you selected an easier one!
Your four-pronged cord has two straight lugs on it.
These are "HOT".
You also have two more lugs, one is round, and one is "L" shaped.
Those two are "ground".
Here's how they attach.
Inside the rear of your machine are 3 screws/nuts in a row.
The outside 2 screws/nuts are both HOT, and it doesn't matter whether the red wire goes to the left one or the right one.
Same with the black wire.
Goes to the left or the right.
The center screw/nut is for the white ground wire.
The other wire (maybe green or maybe blue) should be attached to the side of the hole where the wire enters the dryer.
That one should be put under a screw on the side of the hole, fastened to the "case" or the body of the dryer.
Be blessed.
