I am not sure which Version of Life pad you are using. If it is a 3G or just the Wifi Version. If you have 3G version. You can enable the packet data only in the 3G settings found in the Settings to get internet access.
If you only have a wifi Version. You just need to go to Settings then Wifi and select the name of the network to connect and have internet access on the tablet.
3G and wifi are two separate ways of accessing data on the internet. 3G will use up your phone's data, while wifi will just use the internet you use at home.
The information included with your question says that you have a 3G iPad, but it does not indicate that you have WiFi. If you have WiFi, touch the Settings app and, if WiFi appears, make sure that you are logged into a local WiFi network. If you have a 3G-only iPad, you must arrange for 3G service with your current, or another, phone provider. 3G service is considerably slower, and more expensive, than WiFi.
There may be a conflict between the wifi and 3g network.Shut off wifi to check for connection again.Then do opposite,shut off 3g to connect to wifi only.
First of all there are two types of kindle, the kindle 3g + WIFI and the Kindle WIFI. If you bought the kindle WIFI you will be unable to connect to a 3g network. If you bought a 3g model you can access 3g internet by pressing the 'menu' button and then using the 5-way to navigate to 'turn on wireless'. Once wireless is on you can access your browser by clicking menu, scrolling to experimental and then selecting Web Browser
Cheers
Sine Wave
Your question is very messy. I don't understand what are you trying to say.
Connecting to Internet need WiFi (your home wifi through your router, cafe wifi hotspot, etc) or GPRS (data connect through your carrier/SIM, like 3G, 2G, HSDPA, Edge).
For WiFi, normally you'll need a security key.
For GPRS, you'll need some settings from your carrier.
_______________________________ Sent from my Galaxy Tab using Tapatalk
_______________________________ Sent from my Galaxy Tab using Tapatalk.
FYI: We the administrators of (mygalaxytab.net) do not endorse any posts of discounted third party phone sales. Be careful as they may be con sites and most usually .
Generally all laptops with wireless built in have a shutoff button for the wifi connection. While you need the internet turn the wifi off. When you need to print, turn the wifi on, print then turn it off. It is not the best solution, but it should be a short term work-around. The other option is to attach the printer to your laptop with a cable (usb or otherwise). Turn the wifi off. Add more info to your request if this does not solve your problem,
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
