When I turn on the oven there is a heavy semi unburned gas smell till the oven is completely heated. Seems to me the amount of gas introduced in the burn area is much too much in relation to air volume therefore causing a heavy un breathable air in the room. How can I adjust the burn or air to gas rate? Please help.
SOURCE: how can you tell if
Most ranges are easy to convert from propane to gas or vice versa. If there is a gas regulator installed on the back gas inlet, you could see if it is running 3-6" WC or 10-12" WC, The latter is for propane. If no regulator is present the orifice sizes will need to be checked. Propane has a higher caloric value than natural gas so the orifices are smaller. One way to see would be to install the oven. If the orifices are for propane and you are using natural gas there will be too little flame. I would estimate a conversion would cost no more than $250.00 to $300.00 depending on where you are. I would hire a professional to verify. I know it is expensive but the technician will be able to check your older oven (1985) for potentially dangerous gas leaks etc while he is there.
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
Check the temp sensor as this may be on the brink!
