I tried to call them but they just lead me to the numbers of local service shops.
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Hello byseltrd03 - Try resetting the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the dryer back on. Check that the power cord is not damaged. Otherwise the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. Should all troubleshooting measures fail, I strongly recommend contacting a local professional for further diagnosis. You can often locate qualified servicers by visiting the manufacturer directly.
Hi stormsdestin - Thank you for your post! The electric range, model number FEF353BFW is recommended to used warm soapy water to clean the electric cook top. If your cook top is broken or damaged, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. However, if you are requesting information on what kind of cook top repair creme may be use I would personally suggest contacting the manufacturer directly.
