Question about Kenmore 600 3.5 cu. ft. Top Load 110-2962 Washer
Kenmore Washer 600 --Softner is empty out during wash cycle
When I wash a load of clothes the softener drains out during the wash cycle rather than the rinse cycle.
6ya staff
SOURCE:
Anonymous
  • 261 Answers
SOURCE: Leaking // bleach/fabric softener dispener isnt emptying
Cat has it correct, the parts are on my van. I would also check the timer as there is also a service flash on a timer that doesn't allow the rpm's above the critical spin of 430 rpms.
Posted on Sep 10, 2008
Anonymous
  • 163 Answers
SOURCE: Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Posted on Feb 13, 2009
Paulo
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: 22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Posted on Aug 30, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: F02 Error Code on Kenmore
Hello, welcome to FixYa.
Based on your information posted I understand you have the Kenmore HE3t washer, correct ?
Reading your description and factoring in all you've done and inspected, it may in fact be a faulty pump...(the F02 ultimate worse case) even if it is draining slowly it does not rule it out, trust me I've seen many of them.
By reading your post I've gathered you are pretty thorough so I don't expect you missed it, but I must mention it or I wouldn't be thorough either, I think you can appreciate that, have you checked the back-flow/check ball ?
If not, here's how...
Pull the boot off if you have not and just see if anything has got in there to obstruct the "ball" from working correctly. It is shown here...(this is from the back, but you can do it from the front...just not as easily...in my opinion)
Undo the clamp and inspect inside...if you have not already.
It's amazing how often I find this ball "stuck" or the bellows clogged with debris of all sorts of items...definately worth looking into before declaring the pump has failed. Good luck. Let me know how you make out as I said and if I can help you in any manner going forward I will do whatever I can.
I've also included a more thorough link of my repair tip below
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Regards,
Macmarkus :)
Posted on Sep 11, 2011
Softener tray is not draining during wash cycle
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Feb 17, 2015 | Kenmore HE3T Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Fabric softner cap keeps coming off during cycle
Push the fabric softener cup down and turn it to lock it into place
Dec 28, 2013 | GE WBSR3140DW Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
How to fix suds lock on Kenmore
The Sd code on most Kenmore Elite HE washers indicates a suds lock (usually caused by excessive suds do to overuse of detergent). Check for the presence of excessive suds in the washer. If you see a lot of foam, the code is likely caused by this problem. You will likely be able to drain the washer and spin out the clothes once the suds dissipate. Run an empty cycle with 1 cup of liquid chlorine bleach through the washer to help rinse out suds residue. If you see foam emerging during the empty cycle, you may need to repeat this process. You can also use Washer Magic or AFFRESH to help clean suds residue out of the washer. These products are available at your local Sears store or the grocery store. Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity. You may need as little as a tablespoon of detergent in a high efficiency washer due to the low water level. You may need even less for a while since the clothes will likely have detergent still dissolved in the fibers that will emerge during subsequent wash cycles.
There are many different models of Kenmore Elite HE washers. If you do not see any apparent problem with excessive suds or need more help, resubmit your question with additional details and the full model number of your Kenmore Elite HE washer.
Jan 11, 2011 | Kenmore Washing Machines
Kenmore Elite spraying fabric softener all over clothes and tub
hello mam
is this softner provided by the kenmore dealer if not please getit from them because they know whish softner should be used and for the spots use descaling powder and run the machine without loading clothes.
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Softener dispenser
if softner has discharged it's probably working ok some water left behind is normal
Jun 18, 2008 | Kenmore 44921 Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
