Radio Communications Logo
Anonymous Posted on Mar 26, 2013
Volume not working ,no volume unlees you listen really closely
This is a great little docking station until one day out of the blue it stopped giving volume unless you put your ear up to the speakee you cant year anythi g1
  • Anonymous Mar 27, 2013
    this is a bush ne-3276PLL ipod hifi system, please help
Dr Jeffrey Morris
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 122 Answers
  • Posted on Nov 07, 2013
Dr Jeffrey Morris
Expert
Level 2:
New Friend:
Greenhorn:
Answers
122
Questions
0
Helped
28570
Points
293
Audio socket damaged Re: Jeff
3helpful
I haven't played my wii in a while and have just plugged it all in and my controllers are not working. They don't seem to be charging in the docking station, their individual docks are not lighting up...
Yes they should light up blue when they are charging.
Double check and make sure your docking station is still plugged in and turned on.
Most Docking stations are third party accessories, meaning, they were not manufactured by Nintendo. Some of them do not work very well.
If all else fails, remove the rechargeable battery pack from the Wii Remote and put regular AA batteries inside of it. The Wii Remote should work just fine.
Personally, I prefer to use rechargeable AA batteries rather than charging packs or docking stations. The charge packs/docking stations just never seem to work as well as they're supposed to. The rechargeable AA's work great and they're much more versatile since they're not limited to use in the Wii.
Works great , but Ipod dock only will give about half volume
All Ipod docks bypass the audio processor, so your volume and equalizer presets on the ipod will not work. Use the volume knob on the home theater unit itself.
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
20helpful
6answers
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
1helpful
2answers
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
17helpful
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Headphones
Either the resistor that shuts power off to your speakers when it is plugged in is either missing, shorted, or blown. If you know where to get the unit fixed, that should take care of the problem.
2helpful
3answers
ILive docking station not working properly
hello everyone with this problem I bought a use unit last sunday and it was working ok till next day then not sound not light , I try to push every botton and shut off and on but nothing , after many times I decide to open the boom box , and resoldering all the connections take like 1hour but now the unit works perfect the only thing is the blue light never came on , but cd works fine and radio also the dock for the ipod , is working fine
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
