Question about Toshiba Satellite L500 Series Notebook
Soundboard not working
We bought 2 to toshiba L500 laptops. One that works the soundboard is completely shot. And the one that doesn't work has a working soundboard but we have no idea How to open it up and switch it to the working one, we are out of warrenty and it would cost more to Get fixed by a pro than the laptop is worth. Can you send any instructions or direct us to a video? Please and thank you.
    Master:
  • 551 Answers
You can read the catalogue.
Posted on Mar 27, 2013
6ya staff
SOURCE:
Bob
  • 38 Answers
SOURCE: Toshiba Laptop wont work unless plugged in.
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
Posted on May 13, 2008
Anonymous
SOURCE: turning bluetooth connectivity on, toshiba a200 satellite pro laptop
6500 camera problem when i switch the camere it says not ready please help me to unlock it,...
Posted on Nov 16, 2008
Anonymous
  • 66 Answers
SOURCE: Toshiba laptop P100-ST9612 majors problems--NOT fixed by Toshiba.
oooo man that ones a doozy, if its the one with the go9700 video card its a pretty bad model. the card brand new is 700+ from toshiba. i have run into that problem quite a bit.
Posted on Dec 01, 2009
arianainima
SOURCE: My laptop window 7 Toshiba Satellite Pro L500 loss
try to find your hints. if you can not find so you must need to change window.
Posted on Dec 03, 2010
John Cunningham
  • 6771 Answers
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Posted on Apr 15, 2012
I am trying to connect a computer to a peavey src 4026 to record sermons
Why not un-complicate the circuits by eliminating the soundboard first?
May 11, 2017 | Peavey Music
Toshiba satellite pro l500 2011 Tear down access the 3G blue motherboard add a sim card, How to enable its laptop to internet capability mod?
If you want to sacrifice your wireless then technically this could work. The wireless card is generally connected via 2 wires that can be disconnected. If you have a 3G 'card' with the same connector to the motherboard, and also if there is software / drivers to work the card in windows, the this may work. A much easier solution would be to purchase a 3G USB dongle.
Apr 17, 2013 | Computers & Internet
No sound i thnk my son hooked upmore speakers or smthnh they tol me to start with fuse
Sounds like a motherboard called a soundboard there should be a fuse on the soundboard (ps thanks for scratching your **** on camera)
Apr 02, 2013 | Televison & Video
It happens that the slim cable for the sound inside the computer is not connected to the motherboard. It is not easy to find the right connector on the motherboard. It is better to ask the help of a technician to do the connection.
Jan 21, 2012 | HEWLETT-PACKARD Pavilion Slimline s5510f...
My screen on toshiba satellite l500 went white. I connect it to the tv and it works. Tried re install drivers, made the updates, took out the battery, and nothing worked. Ideas? Urgently? Thanks.
The data connection cable between the lcd screen and the motherboard of the laptop is damaged - the laptop will have to be completely dismantled to have it replaced.
It's a big job, take your laptop to a repair shop.
Jun 23, 2011 | Toshiba Satellite L500 Series Notebook
I dont have sound on my laptop
A general case might be to take the stereo headphone output of the laptop and feed it a set of left and right line level (not microphone level) inputs to the soundboard. Radio Shack sells a cable that has a typical mini stereo headphone plug on one end and a pair of RCA Phono plugs on the other end. If the soundboard does not have phono jack inputs you will need some type of adapter plug on the ends of the cable phono plugs to match the soundboard's connector.
You then experiment with the laptop's volume control setting (start low) and the soundboard's input level control to get undistorted sound with minimum noise and hum. If you can not get rid of the hum, you probably need to add a ground loop isolation box (also available from Radio Shack, I believe) to reduce or eliminate the hum. __________________
Sep 20, 2010 | IBM (01K2154) Sound Card
Toshiba 61H70 projection TV. Perfect picture but the sound suddently stopped working. Tried all on screen settings and still no sound. Set is 8 years old but relatively few hours. Is it worth repairing?...
it sounds like the soundboard went out on the tv..its probably worth fixing but you have to know what you are doing if you do it on your own.it could be something more minor too but not sure
Feb 24, 2009 | Toshiba 57H81 57" Rear Projection...
Sound card
Probably the contact between the soundboard and the mainboard; see here
Jan 08, 2009 | Compaq Presario R3000 Notebook
Not working
Check if the power signal in the base turns on. If not two things can be appening. The base or it's transformer is damaged, or the output jack of you soundboard is dead. Check the sound form the soundboard with some regular headphones to find the source of the problem.
Make sure that the base and the wireless phones are on the same channel and you batteries are fully charged.
Dec 01, 2007 | Philips (33-01-031) Headphones
Toshiba Satellite L500 Series Notebook Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
