Question about HP Pavilion Computers & Internet
Black screen with j and flashing cursor - Pavilion HP Computers & Internet
    Master:
  • 551 Answers
You can call the fixer.
Posted on Mar 27, 2013
6ya staff
SOURCE:
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Screen is black
If you're getting just a flashing cursor on a black screen it's probably a motherboard/video card/hard disk problem (probably motherboard).
If there's not even a flashing cursor - just a black screen - you can add a failed power unit to your list of problems.
The easiest way to check is to borrow a power unit and video card from a friend's computer. There's no need to remove your existing power unit. Simply disconnect the power cables from the motherboard and connect the spare power unit in its place.
If your computer powers up it is obviously a faulty power unit to blame. IIf there's still nothing on the screen, power down the computer and replace the video card with the spare one. If there's still nothing on the screen when you power it up then in all probability your motherboard is history
Nov 29, 2013 | HP Computers & Internet
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
My toshiba laptop will now only turn on to a black screen and a white flashing cursor. I cannot put it in safemode. I cannot put it in boot menu. It goes straight to black screen with white cursor.
it sounds as though its not seeing the hard drive. Power up and press delete to get into the bios. The hard drive should be seen in the first or second screen. If its not there then you will need a new one and a new installation of windows.
Aug 29, 2011 | Toshiba Satellite L645DS4037 Notebook PC
I have an hp mini 210 netbook....it will not boot up...when I turn it on it goes straight to a black screen with a flashing c cursor....i try to ctr alt del to no avail....it will go to the startup...
when the cursor comes up type windows and hit enter. if it stays at the cursor type dir then enter and look to see whats in the directory of your pc. you can try using some of the help keys there to see if you can get back to windows. if nothing happens the you will need to reinstall windows.
Jan 16, 2011 | Computers & Internet
When I turn my comp on, I get the Dell screen, then a black screen with a flashin cursor. When pressing f8 for safe-mode, nothing happens. Just a black screen with flashing cursor. Please help
Unplug all external USB devices to your computer and power it back up again.
If you can start the computer, then you probably have a faulty USB device connected to your computer.
Nov 15, 2010 | Dell Dimension 2400 PC Desktop
Screen is black with flashing cursor
Try to make sure that the first boot is set to CDROM.
May 02, 2010 | Fujitsu LifeBook C2330 Notebook
Black screen with flashing cursor
It may be because of your hard disk damage or OS problem. Try to install a fresh copy of XP from a cd. boot from XP cd and install .
Apr 06, 2009 | Toshiba Satellite M35X-S311 Notebook
Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Feb 15, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
