Question about Edirol UA-25 External Sound System
Two Edirol UA 25 audio cards cannot be used simultaneusly in Nuendo 4?
I cannot reach two same audio cards (Edirol UA25) works togheter in Nuendo 4. I've tried with UA25 drivers, with the ASIO4ALL, and with the Asio Full Duplex Driver. Somebody can help me?
    Master:
  • 551 Answers
You should try it according to sound system.
Posted on Mar 27, 2013
  • rcastagnolo
    rcastagnolo Mar 28, 2013
    Hello Nandini. Thanks for take a time in gime an answer. I don't know certainly what are you reffer with "sound system". I'm using Nuendo 4 running on Windows 7 64 bits, and in the ound setup of Windows, I was set the "Hgh Definition Audio Device" as predetermined audio devce.
6ya staff
SOURCE:
Ua25
Hello. Sometimes the USB voltage is not enougth. Try connect the usb cable into another USB port, preferring the rear panel connectors. The UA25 drivers must be installed previously.
Feb 07, 2013 | Edirol UA-25 External Sound System
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Digital in out
The ada800 gives out 8 channels of ADAT, the edirol UA-25 are only stereo opticals and not compatible with the ADA8000 as it does not have any adat inputs or outputs.
Hope this helps
Jan 31, 2010 | Edirol UA-25 External Sound System
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
My Edirol UA-25 suddenly is not working with Nuendo
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Jun 10, 2008 | Edirol UA-25 External Sound System
Edirol ua25 jack speaker output
Your are using powered speakers right? Or going into an amp and then the speakers, as the UA-25 does not have enough power to drive passive speakers.
Call Roland customer service and have them walk you through the device setup to make sure you've got everything right.
EB
Jun 06, 2008 | Edirol UA-25 External Sound System
Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Edirool ua25
What version of windows our you running, you might have to go to control panel and make sure it is the default audio out
Jan 21, 2008 | Edirol UA-25 External Sound System
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
104 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ekse
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
