Hi-speed 1x
SOURCE: Modem are not connect in reliance netconnect
if you can, remove and reinstall the modem and/or the program.
look at the cable fittings and see if something is broken or bent.
try your local geek network online.
go to your usb port settings and see if it is reading the proper link to your modem and see if your modem is recognized.
may be the network settings you have. in conflict with your modem and network router.
SOURCE: Reliance NetConnect
I
also purchased CDMA 1x but i have good speed. change modem setting put
"DNS" 8.8.8.8 & "Alternate DNS" 8.8.4.4 and type in "Static Ip
address" 8.8.8.8.now connect internet check speed.it's not high speed
we are satisfied.bye.
SOURCE: how to install reliance lxu800
http://www.topshareware.com/reliance-netconnect-usb-drivers-lxu-800/downloads/1.htm
It might work.
SOURCE: how to find my reliance netconnect model zte ac 2726 imei number
dont you see it on the sticker stuck on it? no problem if you dont get just contact the reliance care,they will tell it easily because it is a cdma modem
