I recently moved the machine, without the anchor bolts, I have checked and the springs are connected. as well as the bars on the bottom of the tub. If the sprigs have been stretched could that be my problem
The shock absorbers may need greasing, Put a bit of grease (the thick motor type) around where the smaller diameter part of the shock absorber enters the larger part, the take of the lid (isolate from mains) and give a a few hefty shoves on the drum downwards to help the grease to work in. Excessive knocking on the lead up to full spin could also be caused by an uneven load, the unit as a whole not being level or the unit being located on a joisted floor which increases vibration.
Hope this helps
SOURCE: washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
SOURCE: Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see
o circular lid there, turn it on anti-clockvise to open. All of the
water blocked will come from there, be careful. Look carefully that
there are some objects blocking the water draining. Then turn on the
machine on draining programme, the plastic rotor should turn fastly
when the machine is on. If it is not running, change the pump motor. If
it is running, but machine is not draining again you can understand
that there is an objeck stuck on the hose between drum and pump motor.
Lay down the machine on its rear facade, you will see a large and black
hose between drum and pump motor. When you remove it, you will see that
there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
