Hello Here is some more information for you to follow to guide you step my step. Device displays a white or red cross If your navigation device displays a cross after you switch it on, it means that the TomTomapplicationis not installed correctly. Note:It is normal for the navigation device to show a cross while it is connected to thecomputer.
The solution depends on which TomTomsoftwareis used for updating. Check which software your navigation device uses for getting updates. Devices using MyTomTom for updates For navigation devices that use MyTomTom, reset your device. Devices using TomTom HOME for updates For navigation devices that use TomTom HOME, you can solve this problem by installing the latest application on your navigation device.Here is also a link that will help you more. This will answer all your questions Mike http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
It is quite common tomtom bug. Do: 1. backup restore or
2. copy all original SD files to your new formated SD card. Restart TomTom and
see if it works.
With the right piece of hardware and software, it ispossible to triangulate your location anywhere on earth using satellitenavigation. These gamin devices cansuccessfully guide you from one place to another, or they can simply use theconnection with the satellite to tell you your exact current location. Thelatter function requires you to know how to locate the GPS device using theoptions onscreen. 1 Purchase a GlobalPositioning System (satellite navigation) product. There are manymanufacturers, including TomTom, NavMan and Garmin.2 Turn on the GPS and leave itfor a minute or so as it establishes a connection between the device and thesatellite. 3 Navigate to the"Current Location" option in the "Tools" or"Settings" menu (the exact pathway to this option depends on whichGPS device you have). The satellite signal will now successfully locate yourGPS device.4 Type a ZIP code or placename once you have located your GPS device. The gamin can now successfully guide you to your finaldestinationThanks.
Your best bet is to reinstall the maps, from scratch. This will ensure that all the maps are included. This guide should help you out: http://www.tomtom.com/support/solution.php?GID=1&PID=1682&CID=224-225&Language=1
