I have a model 110.4756 with a cut in the drain hose. doesn't seem like it'd be tough to replace, but I'd kind of like a manual to look at the parts breakdown on it before I start taking panels off. Anyone have a link to this. Owners manual doesn't tell you anything.
Https://www.youtube.com/results?search_query=replacing+model+110.4756+drain+hose.
click on this link and review numerous videos you find there and although you might not find your exact model you will find enough info to do your replacement
SOURCE: Drain Problem
The first thing you need to try is to pull a vacuum on the drain hose to see if you can pull water from the tub. You can do this by using a wet/dry shop vac and connecting it to the end of the drain hose. If the water drains from the washer you may not have a clog. It may actually be a bad drain pump. If water does not flow, or is draining slowly you will need to check the drain pump AND the hose between the pump and wash tub. You can accomplish this by removing the lower kick panel under the door. There are three 7mm screws under the bottom edge. The drain pump is located on the right hand side of the machine or directly in front under the wash tub. It is the ONLY pump in the washer so it should be easy to find. There is a clean-out access that you can remove to clean out the pump impeller. Removing this access will cause whatever water is remaining in the tub and drain lines to come gushing out. That's why it is important to try to remove as much water as you can, FIRST. Even if draining the tub with a vacuum is slow, let it drain. When removing the drain access, look for anything that may be obstructing the impeller. I have found items as small as a Q-tip can stop the pump (believe it or not). In a nut shell: Pull a vacuum on the drain hose - 1. WATER DRAINS EASILY - failed drain pump or obstructed impeller. 2. WATER DRAINS SLOW - Obstructed drain pump and/or drain line. 3. WATER DOES NOT DRAIN - Serious obstruction somewhere in the drain line BEFORE the pump (usually a sock or wash cloth that has worked it's way between the basket and wash tub). *You will notice the drain hoses collapsing as you pull a vacuum if there is a serious clog. Let me know if this helps you.
SOURCE: Washer Will Not Spin - Need to Replace Coupler?
Look for Whirlpool, top load washer, tips (on FixYa). Then search for replacing a motor coupling on Whirlpool top loader. The tip by jsrock516 gives the whole thing. I know you said 'Kitchenaid', but it sounds like the same machine design. Hope this helps and give him a pat on the back if you can.
Testimonial: "thanks a bunch! very helpful (particularly the whirlpool part, which has been stumping me)."
SOURCE: Tub won't drain
The lid switch has a green ground wire and 2 hot wires. Jump them 2 hot wires and see if she pumps out.
More here
bypass it here for testing purposes. How it works: direct drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Frigidaire GLTF2940ES0 Front Load Washer
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
SOURCE: I have a Maytag top
Hello, Welcome to FixYa.
Based on your post I understand you have a problem with a Maytag washer, however if you could provide the complete model number I would be better equipped to assist you without generalizing on what it could or couldn't be.
I can say that most Maytag washers are serviced by way of removing the front panel, though I'd need a model number to instruct how yours is serviced for sure.
Let me know and we can go forward from here. I'll watch and look forward for your reply. Thank you for visiting FixYa for your inquiry.
Regards,
Macmarkus :)
