That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
SOURCE: want to relight pilot
Turn off gas valve to OFF, let the fumes clear out for 10 minutes, THen press turn, and hold in PILOT position, Light the flame (you will see the little nozzle where pilot is) Keep holding for 1 full minute, then turn to ON position and let go and that's it. Your good
SOURCE: Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
SOURCE: Pilot out dryer does not dry.
Hi, If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Hello friend, thank you for your inquiry!
I understand that you want to relight the pilot on your Frigidaire dryer. For this problem I would recommend having a professional come out to the home and properly repair your appliance. One must be very careful when handling gas. -Matt
