CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
The machine cannot send or receive faxes when the power is turned off.
If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
Open the Document Tray.
Open the Document Feeder Cover.
With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
Close the Document Tray. speed printer service
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
