I'm not sure on the recall, but it sounds like either a bad bearing, or bad water pump. If you are interested in figuring it out
Hold and press any button other than the power / or cancel button 5 seconds then let it go 5 seconds do it until all lights come on and it should display an error code. Once it does google it or find the manual. Goodluck
Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
Shop Today at Sears PartsDirectâ„¢. The Largest Appliance Parts Seller. Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
F1 code = Primary Control Failure. Replace the machine/motor control assembly. Call 1-800-659-7026. That machine has a recall for the control board and if your machine is in the recall they will fix it for free.
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
