Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Tray check , pickup roller and make sure you put paper in try is correctly , if you are sure how put paper try to clean rubber " called pick up roller upper try , clean it by wet with water soft wiper ,, hope helping you ,,,
Mohamed Hejazi
SOURCE: HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
SOURCE: I cant print from hp laserjet 1320, orange light is always on.
there is something wrong in your cartridge may be its empty.. replaced a new one
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
SOURCE: hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
Check whether the "print preview" on the screen shows blank too...
Make sure the document you are printing doesn't have blank pages. You may think that it might be one page, it might be two. Somehow you may have inserted a blank page or two.
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from this product or the computer. get more information from here....... http://answers.yahoo.com/question/index?qid=20100905152100AAMq5Iv
