The player is set to "shuffle all" in the settings menu, it used to work just fine but now it won't shuffle the songs anymore. I have also tried the feature to "shuffle all" songs by a certain artist, but with the same result. How do I fix this?
SOURCE: Phillips SA3125 2GB "shuffle all" problem.
I would go ahead and try the firmware update to see if it resolves your issue - for the firmware update to work, you have to get the most recent version of the Philips Device Manager from Philips website. It will erase all the songs in the GoGear, so make sure you have them backed up.
-Tha Mp3 doctor
SOURCE: dont no how to put songs on philips gogear raga
Google search for free mp3 music files and
download them to your computer. Then connect the USB cable that came with your
player, connect it to your player and then plug it into the USB port on your
computer. The computer will see the player as an external storage device, then
copy the mp3 music files to your player.
You can convert your
CDs for free and copy them to your MP3 player. Please click on this link and
follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
SOURCE: I was given a Phillips
Here you go:
http://download.p4c.philips.com/files/s/sa1942_37/sa1942_37_dfu_aen.pdf
SOURCE: My Phillips GoGear Vibe won't
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue If
you need any further help, please email us back so that we can
continue to work on a solution.
To update the firmware perform the below task:
You can set your player to play songs randomly (Shuffle All ) or repeatedly (Repeat
One or Repeat All ).
1 From the main menu, select > Play mode.
2 Press 3 or 4 to scroll up or down the options.
3 Press 2 to select an option.
While you are playing music, you can see the above active play mode screen.
Consumer Care can be reached at 1-888-744-5477.
Hope this helps. If so, let me know by rating this solution. Thank you.
