Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV We need our Sony 52W4100 Bravia screen replaced. What is the cost? Part # 1-802-791-12, cost approx $2,251.54 + core Parts reference: Andrews electronics, 800 289 0300.
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
best bet would be to sell thinde tv as parts on ebay or something. Finding the screen would take a while and it would cost anywhere between $500 to $800. Might as well buy a new tv.
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Broken LCD panel does not affect circuit board behind that panel. Make sure that other TV should be same model (KDL-40W4100) to swap boards / LCD panel because each model has its special designed boards and cannot be used in different model (if chassis is same, few boards can be used)
