After my old hard disk crash I decided to buy a new computer, because I didn't find in shops new hard drives with old connector (not SATA). I afterall I have a problem, my scanner doesn't work under Windows 7! I've tried to find new drivers, but the newest are from 2001 :(( What I have do now? Buy a new scanner - heh, I don't have money for it... So,,, anyone help? :))))
If you scanner only has Win XP drivers, then you have only two choices as those drivers wont work on WIN 7. One is to buy a new scanner, as you have already suggested. The other is to create a virtual machine, load WIN XP onto it, and then install the scanner drivers on the virtual machine. This should work fine as I do it for a piece of software that only works on WIN XP, however it is a bit of a inconvenience to use.
SOURCE: OpticPRo 9636T
Look at this page:
http://downloads.drivershq.com/DriverDetective/DriverFiles/DriverDetective.exe
SOURCE: installing my scanner Plustek Optipro Ut16 I have no CD for this
http://www.plustek.com/support/download.asp Just go to this website , select your scanner model, what u need, OS. Than you will find what you need. Uninstall your scanner and any previous driver before installing new driver. Hope this will solve your problem. Keep informing.
SOURCE: plustek optic film 7200 won't work with windows 7
just install your gadget's windows 7 driver......
SOURCE: Plustec OpticSlim M 12 Scanner Driver for Windows 7 Ultimate
Hi
Please go to the link below
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
and download.
Hope it helps.
SOURCE: load driver. Scanner not found
Welcome to Fixya
This device is completely compatible with windows 7. Please make sure that you have the correct driver. Pelase click this link to download the driver. Make sure you have extractor since this file is ZIP file.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
