Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Posted on Mar 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 4 year old Whirlpool Ultimate Care washer was in the middle of the wash cycle, getting ready to rinse or spin and just died. My fiance went outside to check the breaker. When he came back in, we turned the washer on and tried to put it on the spin cycle. I heard the motor making a whining/grinding noise. The machine would not agitate or drain. We tried the washer on a few other cycles and nothing happened. Now the washer won't do anything at all! Any idea what's causing this?
  • Pierre Le Mesurier
    Pierre Le Mesurier Mar 04, 2009
    Afetr a few minutes of washing, the machine does not work anymore, i tried switching to a different cycle, still nothing ???
  • Anonymous Mar 20, 2009
    I have a similar problem. Mine will fill and drain but will not agitate
David Koss
Level 2:
New Friend:
  • Expert 102 Answers
  • Posted on Mar 14, 2009
David Koss
Expert
Level 2:
New Friend:
Answers
102
Questions
Helped
39697
Points
228
Sounds like the belt broke and probably need replacing or the motor is shot.
My washer was in the middle of the wash when the power went out. i restarted it but it won't do anything except wash, it won't rinse, spin or drain.
if its not doing such in all cycles then i would look at a fault with the water pump have a look at some of my past comments regarding this fault
2helpful
Whirlpool washer stops in the middle of cycle does not rinse and
If your washer stops at the same time each wash, you have a dead spot in your timer. It will need to be replaced. .
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
1helpful
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
sounds like a broken coupling.
it probably don't agitate either.
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
