eMachines EZ1601-01 All-in-one PC 18.5' Widescreen Intel Atom N270 1GB DDR2 160GB Intel GMA...  PC Desktop Logo
Kathleen Mortimer Posted on Mar 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to upgrade to windows 7 from windows xp
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Mar 29, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080384
Points
34431
Go to www.microsoft.com and see the technical specification test for to see if your equipment has the software +hardware availaable for to maintain the instalation for w. 7God bless you
Upgrading windows xp to windows 7 or do i have to upgrade to vista first
You cannot upgrade xp to win 7 because the kernels are so different. You can upgrade from vista to win 7. Just do a clean install of windows 7.
tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
Can I update the operating system of hp mini 311 from Windows Xp to Windows 7?
Update? Upgrade yes.
Windows xp cannot Update windows 7
Upgrade in this particular means Get new operating system,which means it will wipe out your C drive(XP) to a new fresh operating system windows 7.
NOTE: all Xp files and folder might lost on drive C.
[email protected]
tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 • Computers & Internet
2helpful
4answers
How to uppdate from Windows Xp into Windows7 I
Well, it depends on your computer specification because every operating system has it own hardware requirements. Before upgrading to windows 7 make it sure your motherboard support the windows 7 operating system. In your case your motherboard supported by the windows 7 so when upgrading rather formatting your computer you must have the windows 7 installer. Then follow this video tutorial on how to setup your computer to windows 7. Before formatting you must have to back up all your data or files saved on your hard drive. Have a nice day
1helpful
I have an HP m7170n Media Desktop. Works awesome, no problems what so ever. I am running Windows Xp. I would like to know how to find out if I can upgrade to windows 7 64-bit, or if I must stay with...
just go to this site and download upgrade advisor and it will tell you what your pc is capable off and what to do to make it compatible if needed. http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx. be patient since this does take longer time to run. it will give you all details you need. here is a link from microsoft site to update from xp to windows 7 with all steps. http://windows.microsoft.com/en-us/windows7/help/upgrading-from-windows-xp-to-windows-7. Hope this helps.
5helpful
3answers
How can i upgrade from Windows XP to WIndows 7?
Hey, just use Zinstall XP7. It can upgrade to Windows 7 and keep your programs and files and everything. No reason to stay on XP, I think - 7 is awesome
My pc seems to have vireses. it has window xp and can it also be updated with windos 7
Microsoft does not recomend yo to upgrade fron windows XP to Windows 7. Fresh installation of Windows 7 on an XP machine is recommended.
Backup your User file, do a windows 7 readiness, and insert the windows 7 DVD into you systems fro a fresh installation.
However, there are third party application like PCMover software that could help you to upgrade from Windows 7
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
