Repeatedly attempted to install Epson V600 on Windows Vista system (also tried Windows 7). Control panel shows good install, but no matter what I try, when I try to scan, I get a message that says the computer cannot communicate with the scanner. Anyone have any luck fixing this?
SOURCE: scanner not scanning
Your 'transportation locks' may have been engaged. (Check lower-left-hand-corner of the inside the scanner cover and the left-back side) See the manual: http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
SOURCE: Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
SOURCE: Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
SOURCE: Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
To download and install the System Update Readiness Tool, follow the steps below:
1. Click Start
Collapse the imageExpand this image
, and click Control Panel.
2. If you use Windows 7, click System and Security. If you use Windows Vista, click Security.
3. Under Windows Update, click Check for updates.
4. The System Update Readiness Tool (KB947821) is offered, only when
5.
Click Install updates.
hope this helps
