None
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
SOURCE: My LG Tromm Dryer is making a horrible squeeking
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Manually turn the motor and drum and listen for the
noise, if so the motor bearings, the drum agitator shaft and fittings must be
checked. Also the suspensions which include the shock absorbers and springs,
the body clamps must be checked to be in correct alignment and not changed in
position. Tightening of the mounting is
also very important. Finally in most cases a drop of OIL or smear of grease on
the moving parts cane solve most issues.
Check this link :
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
