Question about Whirlpool WTW6500W Washer
Wtw6500 wont agitate
Wont agitate not filling sounds like its draining
6ya staff
SOURCE:
benham
  • 125 Answers
SOURCE: ultimate care 2 wont drain or high spin. does agitate ok
Try pushing down on the lid, if the machine starts to drain and spin you need to adjust the hinge on the lt side. To do this you need to take the screws most of the way out on the back of the control panel ( on the end caps). Then remove the spring clamps that hold the cabinet onto the base. Use a screwdriver into the front of the clamp and press to the back of the machine, then unhook the connector for the lid switch. Pull the cabinet forward and you will be able to see the hinge, use a channel lock or pliers to bend the end of the hinge towards the back of the machine, the lid will need to be open to adjust the hinge. it will only take a small adjustment. After adjusting shut the lid and listen for the click to see if it was enough. Hope this helps
Posted on Jan 10, 2008
lenwest
Len West
  • 150 Answers
SOURCE: will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
Anonymous
SOURCE: Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Posted on Apr 16, 2009
honeymokey
honeymokey
  • 3113 Answers
SOURCE: whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Posted on Jul 26, 2009
Vanguardian
The Vanguardian
  • 106 Answers
SOURCE: washer fills,agitates butstops instead of going into the drain an
Most likely it's the door switch that tells the washing machine that the door is open or closed.
It's usually on a lever of some sort as to not get the actual switch wet that contacts the door itself.
With the older machines in particular, they didn't find filling or agitating as dangerous. Only spinning was considered that way, so it could fill and agitate with the door open and spin only when it was closed. When it spins, it also turns the impeller (pump) in the direction to pump the water out.
The other possibility is that the transmission or motor has gone bad. The motor and transmission turn in one direction for agitation and in the opposite direction for spin. If the gears have stripped in the transmission or one of the primary windings has gone on the motor, it simply won't turn in that direction.
Posted on Sep 23, 2009
Washer wont agitate
sorry only the local washing machine engineer is the only hope eric
Jan 01, 2018 | Washing Machines
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Agitator doesn't agitate. Fills, spins and drains
Unfortunately, that sounds like a transmission issue. Power is getting to the trans, or it wouldn't spin, but the other part of the trans that causes agitation is broken.
Nov 15, 2009 | Washing Machines
Will fill water but agitator wont run.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool WTW6500W Washer Logo
22 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
