GE Accesspoint Keysafe-original - In Package Logo
A
Anonymous Posted on Mar 30, 2013
Unlocking a GE Accesspoint Portable Keysafe - GE Accesspoint Keysafe-original - In Package
1helpful
I just purchased it but it is close, what is the default safe code to open it? Thanks
RUSH BACK TO THE STORE WHERE YOU BOUGHT IT. The only one who can give you safe code is the one who sold it to you.
As if it has a default code? Electronic cosdes might be reset but of sourse, you should know the original.
https://www.youtube.com/watch?v=_tqTp57YfCw
http://www.safeoptions.co.uk/blog/how-to-change-number-on-keysafe-lock/
In any case, if someone with experience with a safe similar to yours might be interested to share his experience, you should provide make and model of you unspecified safe.
I've been lookin for safe mnauls on internet and got this one:
http://www.sargentandgreenleaf.com/pdf/630-302_6120_op.pdf
and also this one:
http://hilkab2b.co.uk/manuals/s-25ea%28ii%29.pdf
How To Change Number On Keysafe Lock Safe Options
Guses might find some better information should you provide make and model of your safe.
Change code combination
Setting the Combination
1. Remove the key holder from the KeySafe by pressing the RESET button, followed by the OPEN button. Pull down on the key holder from the bottom of the KeySafe
2. Remove the bracket. Press the Release tab on the bracket and slide the KeySafe upward until it is free of the bracket.
3. Remove the plastic card attached to the bracket. You will see ten numbered buttons with arrows. These numbers correspond to the numbered buttons on the front of the KeySafe. An up arrow indicates that the button is not selected, a down arrow indicates that the button
is selected as part of the combination.
4. Using the screwdriver tip on the plastic card, apply light pressure
to rotate the arrows on the buttons you've selected for your combination a half-turn to the downward position until it snaps into place. Caution: The arrows must either point up or down, with downward arrows representing the numbers in your combination. If any arrow is pointing left, right, or is not fully seated when turned downward, the combination will not work. Improperly setting the combination is not covered under the warranty.
5. Return the plastic card to the bracket for future use
Pc suite for g five d0
hi..!
hav gfive phone dont worry..!
pc suite for gfive is not available now!
plz specify which os(operating system) u use
sol:
portable Linux operating system which may available in several websites for free dwnload and also free license!
u only need net to downlad and cd to write..!
Plz connect it with data cable if u hav otherwise dont worry buy any bluetooth dongle which may available in cheap as less than Rs.200/-
no need to install pc suite ..!
in any linux now available with already builtin recognising technolgy..!
simply connect and use..!
if u are need to use net via mobile gprs, Dont worry..!
simply give a suitable accesspoint and use ..!
hav any doubt..! feel free to mail my id!
Feb 13, 2011 • Cell Phones
1helpful
Error Code:51030 Unable to find an accesspoint.
most efficient and best way is to download all the repair guide and keep it in our system, we can use this for our personal future use...
click here to download repair guide
1helpful
How do I rename the netgear connection and make it security enabled? I have WG602v2 router
Please follow steps to fix your issue
1. Connect the computer to 1ST Accesspoint using a Ethernet cable.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the Accesspoint (usually http://192.168.0.227).
4. Login to the Accesspoint (Username = admin Password = Password unless you have changed it).
5. click on Wireless Settings in the left hand side menu under Setup.
6. Change the network name SSID to (any name) and click apply.
7. Click on Security Settings in the left hand side menu under Setup and select Security Type as WEP.
8. Select Authentication Type as Open System.
9. Select Encryption Strength as 64 bits.
10. Under Security Encryption (WEP) Key in the Key 1 box enter the same 10 digit key that was used on the router before.
11. Click Apply.
Hope this will help
Thanks for using Fixya
2helpful
Please follow steps to make your network secure and change network name.
11. Click Apply.
Hope this will resolved your issue
I want to set a G604T up as a wireless acces point,can this be done? I have a wired broadband connection but wish to accesss this from multiple laptops
You could just plugin the ethernet output of your broadband into the accesspoint. Now, use your laptops to connect to this wireless accesspoint with security key if any.
2answers
Unlock of a keysafe toggle
Let me know your any email id .so that we can connect again to solve the issue.
I have a PA516 keysafe usb stick & i have forgotten the password
Let me know your any email id.we will connect again to solve the issue.
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
