Qdwscv
Try:
XLSX Repair Kit. The latest corrupt XLSX file repair software featuring a powerful data recovery core and a convenient step-by-step wizard for extra convenience.
For more information: http://www.xlsx.repair/
If doesn't help look for the answer here:http://www.filerepairforum.com/forum/microsoft/microsoft-aa/excel/653-i-get-a-message-that-the-file-is-damaged-or-corrupted
Stellar Phoenix Excel Recovery Tool is an advance or effective software. It can quickly repair & recover damage excel, xls files and virus attacks, unexpected system shutdown, media read error.
For more information visit:- Stellar Phoenix Excel Recovery
Probably it denotes excel file is corrupted. You need to prof recovery software.
I suppose you make use of next one Excel Fix Toolbox
What is exact
problem ? MS excel taking time to open ? Or it is not responding ? If MS
excel is taking time to open, it may be due to Low RAM or low system
configuration. But if is not responding then you need to re-install MS
excel or use excel repair software.
http://www.stellarinfo.com/excel-recovery.htm
Sounds like a corrupt file. If this is so Excel will probably take a month of Sundays to decide it can"t open it. Microsoft does not handle this kind of error in a nice manner. Open the offending file with Wordpad and have a look.
Sometimes files are given wrong extensions and Excel blithely assumes it is for me. Excel should check file header to verify content but never does.
Use in-build "open and repair"utility of MS excel to repair damaged .xlsx files. Follow thesesteps to it
On the File menu, click Open.
In the Open dialog box, select the file you want to open, and click the arrow next to the Open button.
Click Open and Repair, and then choose which method you want to use to recover your workbook.
Most probably your problem may get fixsuppose due to any reason it can't fix your problem then use thirdparty excel repair softwarehttp://www.stellarinfo.com/excel-recovery.htm
It is because your excel file is get corrupted. There are several reasons of excel file corruption; virus attack is main reason of corruption. You can fix this problem with the use of "open and repair" utility of MS excel or you can use Excel repair tool http://www.stellarinfo.com/excel-recovery.htm .
