SOURCE: Carver C11 preamp problem
I found out through the Carver Audio forums that metal shavings inside the case are an issue with this unit. So I used an achohol based spray and cleaned the switchs and the circuit board, (there was a fair amount of shavings found). It has been running for 14 hours with no problems.
SOURCE: Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
SOURCE: Carver CT-17 Preamp Power Cap Values
Hi John...
Are the caps completely destroyed?
http://www.free-service-manuals.com/Audio___Hi_Fi/Carver/index.html
For $14.00 / 3 months D/L as many as 3 manuals a day.
I use it A LOT.
Cheers,
Scott in Verrrrrrrrrrrrrrmont
SOURCE: i just bought a carver ct-17 preamp on ebay and
Try this link - http://thecarversite.com/manuals/files-manuals/Carver%20CT-17%20owner%20manual.pdf
mine is doing the same thing could be a bad transformer according to my electronics repair tech.
