After shutter repair the Av+- button stopped working. All others buttons are working fine and also all camera functions work normally.
SOURCE: shutter button repair
hi it depends on where it broke and if...(the button) if it just fell then u can just take the new button a shove it in untill theres a CLICK if its broke then u will need to pull out the rest and then shove it in DO NOT TRY TO OPEN THE CAMREA IF U DONT KNOW HOW!! you will brake the pins inside when u will and then it will cost u as a new cam good luck windman
SOURCE: Canon 40D not firing
Try doing a reset in the camera tools somewhere, this fixed a similar problem I had.
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
SOURCE: Pressing shutter switches the camera off (40D)
Before you send the camera in for repairs, try this free fix. The problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
There was problem with the main LCD CONNECTION FPC that conect to main board
