Can charge from through the mophie but the mophie itself does not charge
If it's flashing all lights fast at same time....don't worry. My mophie juicepack powestation does this all the time and refuses to take any charge. I bend a paperclip into a u shape and short the pins in the usb output Jack for not even a second. Quick touch is all that is needed. NO LONGER OR RISK DAMAGE OR FIRE. Resets the chip inside. Charges fine then.
Thanks so much. Your solution worked for me. I spilled beer on mophie. I dried it out but all lights would flash when i switched mophie on to charge phone, and iphone would cycle from charging to not charging. thx again!
I totally was NOT expecting this to work, but it did!! Thanks! I dropped mine in the pool bending over to pick something up. It kept flashing after I shorted it so I wasn't sure until I plugged it back in to charge and viola!! THANKS!
that stopped the four lights flashing, it worked
Which usb output port pins do you have to short? There are 4 pins/usb output port
Which usb output port pins? Each output port has 4 pins
I dropped it in water by accident, I took it out straightaway and dried it but there must’ve been some residual water in the connector and the lights were flashing continually and would not stop. I dried it with a hairdryer for a while, particularly in the connector and the lights went off on their own.
It’s safer to plug in a device that needs to be charged to stop blinking lights on Mophie
It's flashing all lights fast at same time....don't worry.
Amazon com Suriora USB Smart Power Strip Traveling 4Outlet Surge Protector...
Why wont my mini mophie charge
