Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We lose audio on our Sony BRAVIA KDL-52W4100
For no apparent reason, we lose audio while watching the TV. To get it back, we have to change the channel and then go back to the one we were. It happens at random, no comun factors for this occurrance.
  • 4 more comments
  • Anonymous Mar 09, 2009
    I have the same problem. Sony support asked me to update my s/w (which I did not even know I could do) via a flash drive they had me update s/w right onto the back of the TV -
    now for the bad news, this did not work - I'm still trying to fix the problem. I just read today a posting on another troubleshooting website to try this ::"you have to bring up the menu on the cable box that allows you to select HDMI as the audio source. I actually found the solution on the Internet, and not from the cable company."
  • Anonymous Mar 10, 2009
    I have the same problem did selecting the HDMI audio source fix the problem?
  • Anonymous Mar 20, 2009
    I have the same audio problem with the Sony KDL - 52W4100 ....
    Usualy changing channels will fix it although tonight it did not work ???
    I tried shutting off my cable box and that did not work ??
    I shut my television off and when it came back on all was fine ....
    I tried my audio that goes to my receiver from the cable box when this happened and it was ok ...
    Don't know how to go into the ComCast cable box to check it ??
    Please e-mail me directly with any help ... jvk52td@aol.com
    John
    I have posted the same problem and got the reply that i need to choose HDMI on my cable box settings. I have a emerson cable box from timewarner cable and i don't see that as an option. can anyone help?
    same problem, it happens about 20 times a day. TimeWarner has checked my cable connections, hardware, etc and changed my cable box 3 times. TV works fine with Wii and DVD, just with the Cable box, which leads me to believe that there's a compatibility issue with the Bravia Sony TV's and the cable boxes available out there.
    Can someone explain to me in step-by-step instructions how to choose the HDMI setting on the cable box? I have an Emerson cable box.
    thank you
We have the Sony Bravia KDL-55EX500. We have intermittant sound outages daily. Cable company has been here eight times in last year. Have changed HDMI cables twice at suggestion of Sony, as well as updated software to latest version. We have changed the cable box three times. Sony blames cable company. Cable Company says Sony Bravia has a defect. They even showed me their Bravia in the cable company offices and said it cuts sound where all other sets dont. This is a Sony defect and they are deflecting. Do not buy a Bravia as Sony will not admit defect.
Posted on Mar 04, 2012
This problem appears to be an issue with numerous Sony Bravia owners of the same model. Although still seeking a soulution, it would appear that our cable provider (Verizon) has replaced all of their components and the Geek Squad from Best Buy where we purchased the unit, points the finger at Verizon. None of our other Fios-equipped TV's exhibit this problem so I am glad we bought the service plan with the TV and will continue to seek a remedy.
Posted on Jun 08, 2009
6ya staff
SOURCE:
TV intermittently loses and regains audio/video from only a couple TV channels
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 28, 2017 | Sharp LC 46SV50U 46" LCD TV
Volume levels vary for no apparent reason. From normal to quiet and back at what seems to be random time intervals. No jiggling of any wires makes a difference. The speakers are old and I'm wondering if...
If you are using it to watch cable TV stations, They may have different audio levels between programming. Also you want to check and not use dolby when atching standard TV channels
Jan 19, 2011 | Audio Players & Recorders
I was watching the TV when it suddenly turned off. The audio fom the cable channel was still running on the independent surround audio system and I could change channels on the cable box. The power light...
Your partial resonance power supply IC with IGBT switch is bad. You will have to have tech replace it for about $50.00. The reason why your audio system still runs is because it is not part of your tv.
Sep 04, 2010 | Toshiba Televison & Video
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Yamaha Receiver loses audio when changing DTV stations
I believe changing stations is triggering the protection on receiver. When you go to another input and back you give time for the protection circuitry to release speakers again. Try muting your receiver before changing channels. Good luck!
Nov 21, 2008 | Yamaha RX-V463 Receiver
Audio problem... channel with no sound
make sure your S.A.P feature is turned off. S.A.P. stands for separate audio program.
Apr 25, 2008 | Toshiba 56HM66 56" Projection HDTV
32F531T color tv loses color after about 15 minutes.
the crt socket of your tvhas a problem,coldsolder the board of your crt socket,if not working replace the crt socket.
Apr 21, 2008 | RCA 32F531T 32" TV
How to record TV program while watching another
how are the cable hooked up? Is there a TV/VCR button because once you start recording, it is at VCR mode, and you need to hit the TV/VCR button to get you back on TV mode,so that you can watch TV.
Jan 03, 2008 | Polaroid PDM-1058 Portable DVD Player
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
1,059 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
