Question about Echo Pb265l 25.4cc Gas Powered 158 Mph Low Noise Padded Backpack Leaf Blower
Blower bogs down and kills at full throttle
Cleaned carb, cleaned exhaust screen, cleaned filter, checked plug proper spacing. starts on the second pull every time, but soon as I turn the throttle all the way up it bogs down and kills. almost like it got flooded but still starts up two pulls later
  • matthew hawkesworth May 24, 2015
    Pull fuel lines out and blow thru with compressed air and get all the gunk out, sounds like a fuel blockage. Mine was the same and I did that and now it runs beautiful
  • Echo Master
  • 1,631 Answers
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Posted on May 19, 2015
  • 7 Answers
Ignition wire fixed my Stihl backpack when it did this last fall
Posted on Feb 07, 2015
  • Echo Master
  • 2,239 Answers
Remove the muffler completly and check the exhaust port itself has not carboned up, if the port is clear, it may be the muffler itself is blocked, try running the machine with the muffler loose, if it revs normally all be a bit loud change the muffler.
Posted on Apr 01, 2013
6ya staff
SOURCE:
Anonymous
  • 5 Answers
SOURCE: Echo Blower dies out when full throttle
Find the fuel air mixture screw located by the carb and turn it so the moter starts to slow down then turn it so the blower runs smoothly this should keep it from dying out
Posted on Nov 23, 2008
Anonymous
SOURCE: echo gt 200r trimmer will bog down once the
If the fuel lines, spark arrestor, sparkplug and carb check out OK, (as mine did) and if it will rev up with the choke partially on, here's the fix:
There is a small plastic plug pressed into a slightly larger brass plug located in the body of the carburetor, surrounded mostly by the white plastic primer housing (between the fuel in and out hose connections). Pry out the plastic plug with a pick and you will find the high-speed adjustment needle. You'll have to back it out a bit to richen the mixture. Using a tiny screwdriver, start the engine and find the point where the engine runs at maximum speed (don't leave it here as you could run the risk of running the engine a bit on the lean side, causing premature cylinder wear). Then, back out the screw a bit more until the engine speed starts to drop a bit. Try revving the engine a few times with the throttle trigger and if it's nice and responsive, you're all set.
Posted on Jun 24, 2009
Anonymous
SOURCE: Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Posted on Jul 09, 2009
Anonymous
  • 33 Answers
SOURCE: Motor not accelerate past idle, bogs down...
yes,check your spark arrestor screen in the muffler
Posted on Jul 13, 2009
Mike McDowell
  • 148 Answers
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Posted on Aug 24, 2009
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
1998 artic cat 500 4x4 starts fine but soon floods gas out the carburater overflow
well sounds like you need to clean air filter if that does not help i would go with your choke is sticking on if its a cable pull one make sure its pushing all the way back on carb check or if it is electronic one i would replace auto choke good luck
May 03, 2014 | Arctic Cat 500 4x4 ATVs
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
Echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
You still have problems in the carb highspeed circuit..some debris in the passages...
BE SURE TO USE COMPRESSED AIR TO BLOW OUT THE CARB.
(be sure to watch the inlet valve seat, you can loose it and not even know it) Blow the carb clean in a box or something that will contain any part that may be expelled during cleaning.
Please take time to rate me
Bud
Mar 31, 2013 | Echo Garden
Husqvarna_blower 125b have adjusted carb but after ten mins shuts off. After a few mins will start up again.
The carburetor or fuel line are the usual culprits. This can be fixed by pouring the fuel into a container to inspect for debris. The fuel line should be drained and blown to cleared completely. Fuel left in an engine can sour and gunk up the inner working. Make sure your using a stabilizer in the mix before storing during winter. Happy Gardening,Coach Dave
Oct 27, 2011 | Garden
I have never been able to start my homelite mighty lkite 26cs weed eater.......
check that fule is getting into the engine and you have a good clean spark plug with a good spark on it and the air filter is clean
try tipping a cap full of fult (2 stroke mix) into the carb throte right into the engine then try to start it up,,if it spluters into life and stops the carb jets are blocked up or no fule is getting to the card
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 25, 2009 | Craftsman Garden
Ryobi backpack leaf blower about three years hard to start
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 24, 2009 | Ryobi Garden
Blower was running fine, stopped for a while and when I atempted to restart, it wouldn't start. Doesn't even try. It always started on first or second pull. This is a two cycle engine. I put a new plug in...
Basics to check:
- aluminum or silver - piston/cylinder scored
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Craftsman Garden
Echo PB1000 leaf blower will not start
Check fuel lines and fuel filter. If unit has been sitting all winter carburetor may need to be overhauled.
Mar 29, 2009 | Garden
Echo Pb265l 25.4cc Gas Powered 158 Mph Low Noise Padded Backpack Leaf Blower Logo
5,344 people viewed this question
Top Echo Garden Experts
Mike
Nick Olsen
choprboz5
Are you an Echo Garden Expert? Answer questions, earn points and help others
