Question about Panasonic Home Theater System System
Plays only cd's no dvd's reads no disc
My panasonic model sa-ht70 plays only cd's. when i insert a dvd it displays "no disc", but i have no problem with cd's please help!!!
  • 42 Answers
The laser lens would have got repaired inside. Please change it.IT will read the dvds. It cost about 25$ i suppose
Posted on Mar 04, 2009
6ya staff
SOURCE:
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
Can Panasonic saht70 play blueray disc
1) you must get the support via ONLINE chat from the manufacturer to see if possible to play blue ray disc 2) the same way get the manufacturer some schem how to connect the speaker without the player.
God bless you
Nov 25, 2013 | Panasonic Sa-ht70 Home Theater Receiver 5...
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*DVD-audio
*PAL system discs
*DVD-ROM
*DVD-R
*DVD-RAM
*+RW
8DIVX Video Disc
*CD-ROM
*VSD
*CDV
*CD-G
*CVD
*SACD
*SVCD
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Jun 09, 2010 | Panasonic SC-HT75 System
The player will not play dvd's or cd's, what might be the problem? The stereo will work, but the discs will not play.
You probably need to have the DVD optical lens to be cleaned. You can also try to buy some CD lens cleaner discs from best buy.
I hope this helps. Thanks and good day.
-HotRatchet
Mar 12, 2010 | Panasonic SC-HT70 System
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
No Disc
you need to replace the laser/optical
Dec 07, 2008 | Panasonic SA-HE70K
Panasonic home theatre system 5 cd changer says no play when inserting dvd
Try cleaning the pickup with a cleaner disc-i'm assuming this unit IS supposed to play DVDs, of couse!
Stan
Mar 19, 2008 | Panasonic sa-ht930 Home Theater Audio...
Won't play
This DVD home theater system has a defect that is not being addressed by panasonic. The Optical lens and or DVD Motor will give out after 2 to 3 years for no reason. It will start saying "No Disc" and will not play any DVD or CD. To repair this it will cost you £100.00 to £135.00 to repair. An authorized panasonic repair company told me that if I repair this it will last me up to 3 years and I would have to fix the DVD Player again. The dvd player model number is SA-HT70 and the number for the system is SC-HT70. The SA-HT70 is the dvd player that is not reliable. Without warning in 2 to 3 years you will have to repair the optical lens or dvd motor which will not be covered by Panasonic.
Feb 12, 2007 | Panasonic SC-HT70 System
Panasonic Home Theater System System Logo
404 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
