Question about Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b
Default ip address to login the symbol spectrum24 ap-4131
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
Hi! I have a number of SPECTRUM24 4131 acces points. I would like tu use them for commercial purpose in a hotel in africa with a web portal for login authentification. I am looking for a skilled person...
What do you need to know / what do you already know ? This is a large question.
1. Are all your access points configured
2. For your captive portal you could use MikroTik software. There is a large community based on the software and step by step instructions to setup a captive portal.
Mar 01, 2011 | Symbol Spectrum24 4131 Access Point...
I want to bridge two AP's but they don't find each other.
the issue is if your using bridge mode then you have to use differnt IP for both Router
if your main router using this IP like 192.168.1.1
second router sute use folowing IP 192.168.2.1
it will work changing IP's
Apr 20, 2010 | Symbol Spectrum24 4131 Access Point...
When we tring to ping for a work station the IP address is on time out?
timeout most likely means that you hit firewall on you way in ( there is router online
Jul 10, 2009 | Symbol Spectrum24 AP 3021
My symbol 4131 and pdt4686 won't associate. Please help.
You can connect a console cable to the console port and login using a freeware terminal emulation app such as Tera Term Pro. The default password is: Symbol
PDF manual:
http://www.guardit.cn/UploadFiles/symbol_ap4131_engmanual.pdf
Use chapter 5 for instructions on creating a new authentication key that will match your computer setting.
Jul 01, 2009 | Symbol Spectrum24 4131 Access Point...
I need user manual of Symbol Spectrum24 4131 Access Point 802.11b
Hello minhaj,
You can download the structure manual of Sympol Spectrum 24 4131 by Clicking Here
Thank you for using FixYa.
Apr 12, 2009 | Symbol Spectrum24 4131 Access Point...
Reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Apr 09, 2008 | Symbol Spectrum24 4131 Access Point...
Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Logo
175 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
