The best way is to use the little screwdriver for to open with the help of some plier. Or use the tools for open the back light in car, is the same type .God bless you
Sunbeam Model: gcsbcs-212
The outlet cord was bad (pinched from falling off the ironing board) inside where the cord goes into the iron.
1. Remove Bottom Sticker
2.Remove 2 Screws
3. Pry off Sunbeam Back Cover
4. Remove 2 screws
5. Pry off Cover
6. Remove Cord Clip (2 Scews)
7. Cut Cord and Strip off ends ( do I cable at a time) Red Circle
8. Crimp back and Test.
any auto parts store with selling tools should have the tool you need take the item down and have them look at it so they can get you the right one.
hope this helps
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
if the screws have a design on top , like 2 half pyramids, then they are dealer screws, so that the consumer cannot open the appliance.....if they are like introverted star shape, then these are called torx screws, can be removed by ordinary torx-bit screw driver, available at most hardware stores....
The back comes straight off. All you need to do is take a small screwdriver and pry against the bottom metal piece, then it should start to come off. Make sure you take it off carefully so as not to break anything. Pry evenly all around the plastic end cap until it comes off.
After that, you can replace the cord. It's connected via two crimp caps. Easy to replace. Just make SURE you purchase a cord rated for an iron.. DO NOT clip the plug end from an extension cord or similar and use it. The iron uses 16 gauge HEATER CORD. Easy to find, but you could melt your power cord and possibly cause a fire if you don't replace it with the correct type.
There is a security screw in the back of the F63D classic iron. It must be removed to get the back plate off. I haven't found the right tool yet myself, though it was suggested it is a "security" Torx.
