Washing Machines Logo
Posted on Mar 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Matag washer may be leaking, esp when in use.
There is water on the floor around where my washer and water heater is located. The WH pan is dry so I suspect the washer is leaking. I have claened up the water so I can determine where the water is coming from. If it's the washer (a Matag), how should I figure out what needs to be done with it. Is there troubleshooting information available specifically for my Matag?
Anonymous
Level 3:
  • Maytag Master 3,361 Answers
  • Posted on Mar 05, 2009
Anonymous
Maytag Master
Level 3:
Answers
3361
Questions
Helped
1028988
Points
10654
Remove the front panel from the washer. Fill the tub with water and then set it for spin.
Look for water coming from the machine. If so, report back as to where the water is coming from.
If no water is coming from the machine......
While the water is pumping out, look at the drain line in the wall and see if it backs up.
If so, call a plumber to clean your drain lines.
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
1helpful
1helpful
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
2answers
1helpful
3answers
Leaking on front driver carpet but no visual sign of leaking around door or windows. Carpet is drenched and so is cushion underneath carpet.
1. Have you been using your heater and is the smell sticky sweet? If so you're heater core might be leaking.
2. Have you been using you're A/C? If so you may have a clogged or disconnected condensation drain.
1helpful
Water on flour of water heater
If your water tank is leaking, is it dripping from above or actually leaking thru the bottom?. Can you find the source? Feel around and try to find wet spots above and around it. If it's not leaking from the water pipes or T&P valve, it's your tank leaking. You'd be wise to have it checked out in the morning, before it gets worse. Hopefully your catch pan has a pipe attached to divert water to the outside or to a sump pump or floor drain. Water heaters do sweat, but you can tell the difference if it continues to leak for several hours.
I have an intertherm split unit and it is getting water all over
hot water heater has a relief valve on it and should have a pipe going down to the floor stick your finger in the pipe and if it is wet inside the pipe that is your source how old os the water heater dry up the floor with towels and leave a/c of for 24 hours not as wet then possible crack in new condensate pan
I have got steam in side my car aii ways
check for water leak in heater core
check for water leak in floor bungs(manufacturing holes in the floor pan filled with rubber plugs
check for water leak around windows doors
check for rust holes in rain gutters above doors, around door sills in floor pan
check that aircon is not set to recirculate air
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
