Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage, then check pump. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
If helped pl say so, thanks.
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
