Question about Fisher Paykel EcoSmart GWL15
Splashing water during spin cycle
Water splashes out from under the lid of my machine during the spin cycle while washing large loads. I've read some postings suggesting the water level may be too high however this particular machine is supposed ot adjust the water level automatically and this has never been an issue previously. Any idea why this has suddenly become a problem?
    Top Expert:
  • Fisher Master
  • 55,370 Answers
Failure of the water level sensor
Posted on Oct 11, 2017
6ya staff
SOURCE:
Anonymous
  • 100 Answers
SOURCE: Maytag washing machine
The lid switch is bad on your washer. Either replace it or bypass it.
Posted on Oct 30, 2007
Anonymous
  • 639 Answers
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Anonymous
  • 15 Answers
SOURCE: Washing machine wont spin the water out.
IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
Posted on Apr 07, 2009
jimorris77
  • 411 Answers
SOURCE: water splashes out of lid in the front of machine
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Posted on Nov 05, 2012
Water collecting under the machine during a wash which is not due to a leak
I had one that would spin water over the top of the drum during the wash cycle once, even with low water level. There are actually brake shoes/pads that add resistance, so the agitate won't over spin before it changes direction. I don't remember them being too difficult to install.
May 03, 2014 | Speed Queen AWS52NW Top Load Washer
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Top load whirlpool washer model LSQ9544KQO leaking small amount
more likely from a hose........need lid off and a good torch
cheers
Aug 03, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Splashing
Most top loaders are not water tight. They are splash resistant. I'm guessing that your water level is too high or you are loading your clothing into a machine that is already full of water raising the water level excessively.
If you allow your machine to fill with no clothes for test purposes, you should see a level about 3 inches below the top of the agitator. If it is higher than that, I suggest that you investigate why or use a lower water setting.
Jun 16, 2008 | Washing Machines
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Adds water at the end of the spin cycle
If it is just splashing the water at the end of the cycle and shutting off-timer issue.
Sep 15, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Fisher Paykel EcoSmart GWL15 Logo
258 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
