The tv will turn on for a few minutes then it turns itself off and continues to blink red- when trying to turn on blinks green- what could be wrong
SOURCE: TV won't turn on. (Panasonic 1080i HDTV)
The power led blinking is an error code if you can reply to this same post and let me know the number of blinks I can assist you with what it means.
SOURCE: the power light is just
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
SOURCE: Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
SOURCE: my panasonic (pt50lc13) keeps shutting off after a few minutes.
probably lamp gone out. You can change it youself if you still have owners manual should have directions, if not most lamps have instructions in box.
SOURCE: I have a Panasonic HDTV 1080i 52inch TV that is 6
Check the lamp. Detach the front cover, read the warning, unscrew the cover, look inside, undo the one and only screw you can find, and pull out the lamp module. (Without touching the lamp) have a look at the light. Can you see it smokey in colour, or is the filament broken? This is how the PT-50LC13-K that I found in the garbage behaved, and the lamp filament is toast. Just thought I'd share.
